Hi all,
I recently bought a 2000 Prado VX Diesel. Now the car had a jap-import motor replacement late November 2010 and I replaced the turbo about a month ago. As far as I know that is all that was replaced. After starting difficulties when suddenly turned off, I put recently reconditioned injectors in to try and solve the starting issue, this seemed to work.
Now, I put the car on a lift two days ago, removed the wheel to check the brakes, tuned the actuator on the turbo and now it wont start. Using the engine workshop manual i checked every electronic sensor/switch working the fuel system except the throttle position sensor - everything is working perfectly but I'm not getting any fuel to the injectors. Even after manually powering the fuel pump solenoid there is still no fuel.
Any help please!!
Erik
Any help please!!
Erik
