UniFilter retailers in NZ?
  • UniFilter retailers in NZ?
    Hi guys, this is my first post. I must say that PradoPoint is a great forum, and I've found lots of useful info already.
    Can anyone help me locate a UniFilter retailer in NZ, preferably Canterbury? The last one I got was from Delta 4WD in Chch, but they seem to have vanished?
    Re: UniFilter retailers in NZ?
    You can buy directly from Unifilter via their website.
    http://www.uniflow.com.au/index.html
    Mick
      My advice is not to fit any type of oiled foam filter. I had a Unifilter. Kept it cleaned and oiled on a regular basis. It was stored for a while while I used a K&N, which I still have. I recently had a check and the foam was disintergrating and crumbling away..
      The lifespan of these filters is quite limited due to engine heat deteriorating the foam. The last thing you want is a piece to pass into the throttle body, injectors, etc. For the price they are not cost effective, and a pain to clean and re-oil. Wash in turps, takes hours to dry (or days depending on climate, then have to squeeze the oil through the outer foam sleeve...very messy.
      The K&N, spray with the genuine detergent, rinse with water, let it dry and spray the oil on. Have had my cleraning kit for 4 years and still using it!
      I would suggest you get a K&N or stay with a genuine Toyota filter as test have proven that they have signifanctly better airflow than a Unifilter.
        Thanks guys - I hadn't really considered any alternatives... I will look into it.
        Jase
