Currently I tow around a five metre plate alloy boat with a towing weight all up around 750kg. The Prado tows this fine and only struggles on really long sneaky hills where you lose too much speed before you realise it. The Dtronic chip made a really big improvement to low down torque.
Now I looking at getting a bigger boat around 6.6 metres which will weigh around 2.1 tonnes fully loaded. I want to be able to maintain a decent cruising speed and be able to climb hills fairly easily I would like some more torque to pull the whole operation.
I have been doing a fair bit of research on various sites and it appears to me there are two options;
1. Get a Diesel + Gas conversion
The base cost I have priced is $4400 less $2000 Commonwealth rebate less $1000 WA government rebate means a net outlay $1400
2. Get a bigger dump pipe 2.75" and free flowing exhaust frpm Beaudesert exhausts for example for around $900.
With gas fitting I would have 40 Litre bottle in the vehicle because the bottle that can be fitted outside is too small IMO.
I don't want the Prado to be noisy so a noise level as close as possible to standard would be nice.
Both options appear to give a decent boost in torque/power and reduce fuel consumption when you are not using all that extra toque/power.
Could I have advice please as to which way would be the best way to go in the long term Question
