D4D motor in Prado 90 series
  • D4D motor in Prado 90 series
    I was visiting London and saw a Prado 90 series wagon with the D4D badge on it. Didn't know that they had this motor in them!
    Same like in Thailand when I saw a Hilux two generations old, also with the D4D badge on it.
    In both cases, the badges are not stuck on by hopeful owners, like you see some cheapie 3 series BMWs with an M3 badge. These were the real mcCoy.
    I can put up a photo, if anyone is interested. :mrgreen:
    Re: D4D motor in Prado 90 series
    Fellow PP member Tommo in the UK has a D4D in his 90 series.
    Adam
    2002 GXL 3.0ltr turbo diesel, ARB delux winch bar, 2 inch OME suspension lift, Safari snorkel, Dual battery system, uniden UHF radio, IPF HIR lights,80ltr waeco 50ltr waeco, 9500lb magnum winch, DPchip,PP stickers, custom rear drawers, power shower, rear work light, ECB roof cage, micky thompson MTZ , hilux bonnet scoop, 3" Taipan Exhaust
    [url]http://www.pradopoint.com/showthread.php?14181-adam-s-02-prado&highlight=adam's+prado[/url]
      OK, I managed to upload it and here it is. Taken in West Mersea, UK.
        The D-4D engine came to europe in 2001.
        This is what it looks like in my 3-door prado from 2001. All original.
          From your photo it looks like it's direct injection engine though and not common rail like the current version.
          Mick
            Mick
            Well, it says "KDJ90" in the papers, and "1KD-FTV" on the firewall.
              Yeah, look I don't doubt you. It was just a passing comment. I just thought that from my (sometimes poor)memory the common rail was higher up and easily visible on our local D4D. In your pic the injector lines appear to run quite far down almost to where the pump is.
              Maybe it's the angle of the pic, my poor memory or maybe there are some layout changes over the years, I guess it really doesn't matter. It's obviously still a 1kd.
              Mick
                I look at the new NG Prado (150 Series) motor, and from the individual injector pipework, it doesn't look (to my untrained eyes) to be a common rail design, but perhaps that's how common rail is done these days.... Toyota's datasheet clearly states that this is a common rail injector system.
                  Ive seen them on Ebay UK for around 6000 pounds , i would love to import one .
                    Common rail is just as it states, the fuel for all cylinders is fed from the one fuel rail, just like it is with an EFI Petrol motor.
                    The location of the intercooler may force the fuel rail to be located lower on the engine, thus making the need for additional single line fuel delivery pipes to the actual injector.
                      MickL,
                      before you pass sceptical judgement at Jema's claim he has a D4D in his 90 series, have a look at the obvious differences.
                      The Throttle body is different from the 1KZTE
                      The Airbox is on the opposite side to the one fitted to the 1KZTE
                      Just two things that convinced me.
                      Wish I could put one in my truck too.
                        Originally posted by WIZARD
                        MickL,
                        What's wrong with you Dude? Did you read my next post?
                        This is the second time you've had a go at my posts publically... the last time still pisses me off and you were being an ass then too.
                        So tread lighty this time and from now on.
                        Mick
