Flashlube Installation
  • Flashlube Installation
    Can anyone help with Flashlube install? Posted couple of weeks ago and no replies I just need to know where and how to connect it to the intake.
    Thanks, Nathan
    Are you using it with LPG kit or something?
    2000 Toyota Landcruiser Prado VR6 VZJ95R, lovell 2" lift, GME TR4200, 32" Federal Cougar MT, Snorkel and lots of mud.
      flashlube
      yes i am using it with lpg
        ill assume its this kit?
        http://www.ochranamotoru.cz/en/stahn...vesaverkit.pdf
        manual from the website
        http://www.flashlube.com/images/stor...t-brochure.pdf
        found a youtube video:
        http://www.youtube.com/watch?v=1x-FIMZ2y8g
        As for the 5vzfe
        For maximum performance the inlet port for the
        Flashlube system should be between the butterfly valve
        and inlet manifold. Fifty
        to 100 mm away from the
        butterfly valve towards
        the inlet manifold should
        provide good mixing with
        the air / fuel stream. If no
        suitable port is provided,
        drill, tap and insert the
        supplied 3mm threaded
        brass connector
        so depending on the model of engine, id just connect it to an existing unused hose nozzle thats located on the intake manifold.
        Had a similar set on my old B2600, used an existing unused vac nozzle.
          flashlube install
          thx, its not the electronic version and there are no unused vac ports after the butterfly. i guess i will have to drill and tap but i need to know where it will be safe to drill without hitting something important!
          Thanks, Nathan
          As for the 5vzfe
            Hey there rthy, why is the brake booster in your picture on the opposite side.???? Cheers Steve
              Just added some random 5vz pic for reference (American?)
              found some pics of a install on a 120 but not detailed.
              http://teamgreenautogas.com.au/defau...do%204Ltr%20V6
              id buy a 2nd hand intake manifold and experiment with that or use as backup.
                There must be plenty of people on here running gas on there 90 with a flash lube kit. Mate Im not 100% sure but I think one of the guys at work has it on his 90. I know for sure its on gas but not sure wether he has bothered with the flashlube kit. Will try and find out. If he has I will try and get some pics for you,I had it on my 90 but never got any pics of under the bonnet......Cheers Steve
