Timing Belt change - what else should be done?
  • Timing Belt change - what else should be done?
    Hi Prado owners, I have owned my 2002 Prado since new, now approaching 150,000 klms. Going to change the timing belt, and asking here what else I should change while doing the job, eg water pump.
    I will probably pull out the radiator and replace all hoses too.
    Any other things I should do at this mileage and age ? (10 years of trouble free motoring - great car !)
    Thanks, Don
    Always replace the water pump, there are many brands of kits out there that have all the gear needed to replace, it should include - a new T belt, new water pump, new cam seals (front of engine), new crank seal, new tensioner pullies, and all the gaskets. and while your at it, you may as well do the rad hoses, and fan belts. There are a few options you can do also, that is to replace the cam cover gaskets and the spark plug tube seals (these are 90% of the time forgotten about), they are only cheap to replace too, so while they are doing the T belt they may as well do them too.
      Thanks for all that Croozza. Will take your advice. Don
        I agree with croozza, I got a reasonabl kit off evil bay to do timing belt on the Prado as well as my wifes Rav4 from same guy.
        90Series GXL 3.4L V6 - Snorkel, sports muffler, 3" suspension lift, 285's, 30mm diff drop, Brown Davis bash plate. Coming soon: 2" Body Lift, custom comp style bar & sliders just for starters
