Hey all I noticed that my Rocker cover is cracked. Can you get new rocker covers for a 2.7? Should I replace the gasket too? How bad is it can I still drive to work with it like this? Here's a pic
Cheers all
Cheers all
I have previously had 5 cars, these have all leaked oil from gaskets/plugs. The worst was a VH Chrysler charger (used to check the petrol and top up the oil) never changed the oil as it wasn't in the engine long enough to get dirty. The leak you have is more of a nusance than anything, if it really worries you you could have it changed and if you do replace the gasket, or another alternative would be to degrease the area every couple of months or sooner if you wish. The main problem with this type of leak is that the oil leaks downward and will in time cover the front of the motor with an oil and dust mixture. It is fine to drive to work.
Ken
3.4 GXL man 1997 petrol / gas, BFG mud tyres 265 75 16, front and rear camera, Jaycar 6300Lm LED 6.5" D/L * 2, 15W LED reversing/work light, diff breathers, 42mm lift, Rear Anderson plug, Dash cam, and way too much recovery gear for one vehicle to carry around. No more HID headlamps. No more Narva D/L.
