Fuel Tanks
  • Fuel Tanks
    Hey All
    Im after so info. Does anyone know if the fuel tanks from a V6 model (Both Main & Aux) will fit to a 4 cyl model. I have been told that the body's are the same so I shouldnt have any problems fitting them.
    I was just wondering if anyone esle has done this or has look into doing this.
    Kile
    Yes can you fit the V6 tanks in a 2.7 ltr Prado? I want to know before I buy.
    97 Vitara 1.6 JX Day Tripper(550klms range), 98 Prado V6 LPG GXL for Touring (1400klms range), Offroad Cub Camper for Overnight.
      Sub tank
      Hi folks,
      Just thought I'd share some of my experiences with this...
      I've got a 1996 Prado RV (so 4cyl). I had it converted to gas, then bought a 2nd hand sub-tank (which I believe only came with V6 models). You have to replace the filler neck (because the stock RV 4cyl only has a tube going to the rear tank - now you need the filler neck to also go to the sub-tank.
      All of this simply bolts on - all the nuts and holes are there on the frame. One word of caution:
      Having done this, mine runs rough on petrol. I'm not sure why yet - the gas place said its possible the subtank (designed for the V6 engine) has too low fuel pressure for the 4cyl engine. I havent connected the fuel hoses up as I'd like (currently I run a 2m rubber hose to the back of the car where the old tank's fuel line is - its possible that the extra distance is too much for the sub-tank pump!).
      So yes, mounting is easy, but double check compatibility! I'll update if I find out that theyre incompatible.
      Cheers!
