smoking 3.4L engine after highway run
  • smoking 3.4L engine after highway run
    Hi Guys,
    I've just picked up a 3.4L 210,000 km 90 series, and found around town it doesn't smoke at all, but after a highway speed drive of over 30 mins, it will blow a large volume of white smoke at the next start. The smoke disappears after a couple of minutes and behaves itself unless another high speed drive comes along. The plugs are quite oily, and I suspect they have been in far too long.
    Other than changing the plugs, any thoughts ?
    Thanks,
    Simon
    Adelgigs
    Lurker
    2010 Prado 150
    Is it running LPG ??? Cheers Steve
      No, standard ULP.
      2010 Prado 150
        Hi simon i was wondering if you worked out what caused the smoke my prado does the same
        Hi simon i was wondering if you worked out what caused the smoke my prado does the same and it has 210 on the clock too
        Craig
        QUOTE=Adelgigs;443909]Hi Guy
        I've just picked up a 3.4L 210,000 km 95 series, and found around town it doesn't smoke at all, but after a highway speed drive of over 30 mins, it will blow a large volume of white smoke at the next start. The smoke disappears after a couple of minutes and behaves itself unless another high speed drive comes along. The plugs are quite oily, and I suspect they have been in far too long.
        Thanks,
        Simon[/QUOTE]
          Quick test would be to start the engine and pull the engine oil cap off. If there's heaps of smoke / vapor coming out of the rocker cover you may find that the engine may be a bit tried. If there's bugger all fumes coming out, then it might just have the wrong viscosity of oil in it.
          96 3.4 GXL, 2" lift, Poly airs in rear, 32" BFG muddies, Lightforce 170's HID's, TJM rack, Awning, Twine on board shower, GME uhf, Dual batteries & monitor, Storage system, ARB fridge, LED rear lighting, Safari snorkel, Brown Davis bash plate, Ironman winch bar, Runva 11xp winch, Roadsafe recovery points, ARB compressor, Tyre dog monitor, AJ's sliders, Hema hn6. The to do list is getting shorter.
            Doing a short road trip this weekend to Saunders Gorge, so will let you know what happens. I've got a new set of plugs to put in before I go. Very odd that your Prado does the same thing, but doing a search it doesn't seem to have been mentioned before.
            Thanks for the comments.
            Simon
            2010 Prado 150
              Valve stem seals perhaps? Compression test should tell you if the engine's tired and if the oil is coming up past the rings.
                If it was vavle stem seals it would blow smoke after having the engine idle for a bit, rather then only high speeds. Would def get comp test on engine done. Just for piece of mind.
                  When I say it blows smoke at start-up after a decent run, I mean an absolute cloud of white-ish smoke.
                  I have just pulled the plugs and I reckon they have been in there for way too long, in fact I would hate the think how long. The centre electrode is about a third in diameter of a new plug, and the two "arms" are markedly burnt back. I'll also run a heap of injector cleaner through it.
                  Perhaps a cause, or just a cause of lousey economy with a weak spark ? It didn't seem to lack any power though.
                  The weekend run will soon tell.
                  2010 Prado 150
                    Does the white smoke smell like raw fuel then?
                      Originally posted by Adelgigs View Post
                      Hi Guys,
                      Thanks,
                      Simon
                      White smoke is not oil, it is fuel. Blue/grey smoke is oil. You may have worn/dirty injectors
                        It might be worth trying some of the "Cost Effective Maintenance (CEM) Products. I've heard some very good reports and if it solves your issue, then u have saved some $$
                          WHOA! Do not do/buy/fix anything yet!
                          Some sage advice that was fortunately beaten into me by my mechanic mate fairly early: DON'T START FIXING ANYTHING UNTIL YOU DIAGNOSE EXACTLY WHAT THE PROBLEM IS! Anyone who has worked on cars for a while will have a tale of all the money they spent chasing a fault and ending up at the tail light when the fault was in the radiator!
                          Do simple and complete overall diagnosis stuff first.
                          For example: you said the plugs were "oily", is that on the exterior or on the business end? Are they "oily" or "wet" (with fuel)?
                          Does the engine oil get dirty real quick? (Blow by past rings, can check with compression test which will also give you an idea of the general state of the engine) Does it use much oil? etc etc.. you get my drift? Make sure you post accurate symptoms so we avoid having to make wild guesses as to what it MIGHT be (not berating you in any way OK?) Accuracy is important, coz at the moment I am not sure whether to advise you to look at rings or injectors and you could waste $$$$ if you get pointed in the wrong direction.
                          The most I might do at this stage is run some injector cleaner through it for the princely sum of about ten bucks ( and change the plugs obviously) but don't throw money at it until you know what is really happening. cheers Steve
                            If you run injector cleaner through it, it wont fix the problem for many tank fulls, it would be cheaper and give you a better idea of the condition of the injectors if you got them cleaned ultrasonically.
                              You can do a Ramflo on the injectors for about $150 approx. Still not as good as pulling out and having them checked and tested.....Cheers Steve
