Hi Carrot
About every 15000k's service the gas
A standard service is not that much $75 - $100 for just a service, replacements of parts if required gets added.
The guy who runs my local center ( reasonably unflappable and been there a while) found a problem though that he reckoned was becoming more common.
Dirty gas! A couple of grommets had dropped out of the bottom of the converter unit and I was losing gas ( alot). It was his belief that Bp had something going on with their ever changing formula /refinement process that left a sediment or residue that ate away at these gromets and they just dropped out. He preferred Kleenheat Gas There was something else he mentioned regarding the gas lines as well but i cant find it in my memory. Someone may have a clearer bottle on this.
It wasn't the cost of the replacement grommets (cheap), and putting them in was easy too , but I also had to have the diaphragms in the converter replaced due to this "issue"
So my $75 leak test, service and reset turned into $280 and an over night stay.
I can get further info on this if its wanted
Ad
Ad
