Originally posted by Gosling1
View Post
Yes the timing is controlled by the ECU so as revs rise and fall the timing is advanced or retarded (for which the knock sensors play a part), but it does not have/can not by any means of anything on the vehicle, detect the octane rating of the fuel used, so it can not increase fuel econ or power of the motor.
What people are feeling is increasing the power of the motor is most likely fresh fuel, as fuel ages the quality drops as does power and econ.
The technology at the time the 5VZ came out was not startling compared to todays standards. The same goes for diesels, look at what they were like back in 1995 (when the 5VZ first surfaced) to what they are now. The problem with most people is they try to compare the tech from then to what is out now, you wouldn't do it with a computer, why do it with the electrics of the motor.
