Conflicting Torque Specs for 5VZ-FE
  • Conflicting Torque Specs for 5VZ-FE
    I'm replacing my timing belt and cam seals on my 1999 Prado. I have purchased a new genuine crank pulley bolt and the Toyota dealer gave me the torque specs of 250nm (184ft lbs). But I have seen on forums where the torque settings is 295nm (217ft lbs). Which is correct?
    Also I would like someone confirm that cam pulley bolts torque specs is 110nm (81ft lbs).
    Appreciate any help.
    Gregory's workshop manual states the following;
    Camshaft sprocket bolt...............110 Nm.
    Crankshaft pulley bolt.................250 Nm.
    Baders-1996 Prado 90 Series 3.4L/TRD Supercharger/2.2" Pulley/Xede ECU/Aquamist Water Meth Injection/Pacemaker Extractors/2.5" Custom Exhaust/West Coast Suspensions HD 50mm lift/Detroit Tru Trac rear diff.
      Thank you
