Long story short, we've got a '97 J90 Prado with 350,000 KM on a 2.7L MT engine and have a bunch of $ and time invested in suspension and off road accessories. My wife took it in for a tune up recently and the mechanic noticed their was oil leaking for the oil seal behind the harmonic pulley and replaced it. He probably didn't tighten it back up and by the time my wife got home none of the pulleys were turning and it turned out the harmonic balancer had been spinning on the crank and had totally "melted' the woodruff key into the crank and gouged it out.
I was busy and out of town and we towed it back. Mechanic insisted it wasn't his fault as 1.) it happened because the car was old and 2.) he had a new boy from Myanmar working on it who didn't speak English or Malay (we're in Malaysia) and so if anything - it was his fault but he was now fired. (That's pretty run of the mill responsibility here for a Malaysian Chinese.) He pulled the engine, sent the crank to a machine shop and added a 3rd key slot for a 3rd woodruff key and put it back together. Engine made a funny humming sound at 3-4,000 rpm's he insisted was normal. Lasted another 50 KM or so before it started making horrendous noises coming from the front, shut down and refuses to start and that's where it's at now.
It's looking like the repair costs will be pretty steep and in all honesty even if the engine was running excellent I don't really like it. I wish it had more power - and for being so anemic it doesn't get very good mileage. So my question is what other engine options are there for this model that aren't too complex to install? I know it had a 3.4L petrol option which from the numbers is only slightly down on mileage and a good boost in power. I like the numbers of the 1KD-FTV common rail diesel... does that fit?
