Fault Codes
  • Fault Codes
    Does anyone have a list of fault codes for a 5VZ-FE? I bridged the terminals to get the CEL to flash the codes and it has some stored, i am pretty sure they would have been from when the MAF was unplugged. The O/D light flashes at even intervals so no faults there.
    Also there is a small sensor on the drivers side guard - grey top, black housing, 3 wires. I have read somewhere about an oxygen sensor simulator and was wondering if this was it (It has R and L underneath it), i presume its just a variable resistor for trimming the mixtures. If so how do you adjust it? I have a widband O2 sensor i can plug in to set it up properly.
    '98 Grande V6 - ARB Sahara bar, IPF HID spotties, ARB compressor, GME UHF, OME Sport suspension, 265/75 MT ATZ 4 Ribs, steel rock sliders, Safari snorkel, Tigerz11 winch, rear ARB locker, Rhino platform rack.
    Re: Fault Codes
    No one got a list of fault codes?
    Figured the adjuster out and am now having play around with it. Its just a 4.6k variable resistor.
