switching engines
  • switching engines
    G'guys, I have a 97 rv 2.7 litre and was curious, is it possible to put a larger engine in like the 3.4 litre v6 in and would it take much to do so?
    Anything is possible. From memory the 2.7 haad a diferent gearbox and diff ratios to the 3.4. Memory is unreliable though.
      Barra swap it. If you're not keen on that as MJR said the box and diff is probably different you'd need to swap both to have the factory equilivent. As far as swaps go it'd be one of the easier kind as it should all just bolt in within reason, depending on time/ money and your mechanical aptitude it might make sense to just fix what you've got.
