Petrol-LPG switching is not smooth
  • Petrol-LPG switching is not smooth
    I bought my Prado with LPG kit already installed. It's great and runs cheap!
    However the switch is not so smooth between Petrol - Gas. For example in the morning once I start (which uses Petrol by default) and drive off, it would decide to cut to LPG and sometimes I do not have the RPM/speed to keep the engine running. Hence the engine is dead.
    The work around until now is before driving off I would Throttle a bit so it switches to Gas.
    What could be the problem here?
    [url="http://prado-resource.blogspot.com"]http://prado-resource.blogspot.com[/url]
    Re: Petrol-LPG switching is not smooth
    Sorry to hear about your dilemma Javaman. Best to get it checked by a qualified gas fitter in your area. They know their products and can usually modify the setup a little bit.
    Good luck
    SSSHHHH be very very quiet were huntin wabbits.
      Agree with D4D-GXL, gas systems are best looked at by the professionals, they will certainly have a solution for you...
        There are a few different brands of lpg systems which all get setup a little differently. There will also be variations in the install between installers to complicate matters more.
        Before you book it in can you provide some more detail?
        - Has it always been like this since you bought it?
        - Does it run a petrol start module? (small black box under bonnet with a few flashing lights and blue text on it)
        - explain a bit better what the lpg cold start system you have currently is, ie does it run on petrol for 5 seconds and the swap or something else?
        Westy
        2001 VX 3.4, Dual Fuel, TJM Nudge, IPF Spots, Uniden UHF, Ming Tint, Dust deflector, side steps, Bridgestone D694LTs. [url=http://www.fuelly.com/driver/Westy90/prado][img]http://www.fuelly.com/smallsig-metric/68370.png[/img][/url]
        [url=http://www.postimage.org/][img]http://s1.postimage.org/gu8j7rlw/prado_avatar.jpg[/img][/url][url=http://www.postimage.org/][img]http://s1.postimage.org/guigfukk/08062010_001.jpg[/img][/url]
          Thank you!
          It seems like not a DIY job. I'd better bring it to the pro's
