Diff drain plug???
  • Diff drain plug???
    I was changing all the oils in my Prado yesterday, all went well exept for the front diff. What tool do i use to undo the drain and filler plugs? Is it just a big allen key (which i don't have) or something else?
    Thanks in advance.
    '97 Prado RV 2.7 LPG, 2"OME lift TJM bullbar, airtec snorkle, 72 lt aux fuel tank. Wishing for better front seats!
    Diff plug
    If its the same as the 120 series you will need a 10mm allen key.
      1/2 right. The filler plug is a 10mm allen key, but what size is the drain plug? It looks like 12-13mm, i don't really want to have to buy them all if i can help it.
      Should have just measured it while i was under there i know!!!
        I recently drained my front diff and used a 10mm Allen key. From memory the drain plug is large and flat, where as the filler isnt quite as large, but the 10mm key definately fitted both plugs.
        I did have some problems getting the key into the drain plug because some mud had rusted into the socket. I had to scrape out the edge of the socket to define its shape, and then hammer the key in place until was secure.
        When I removed the plug I cleaned out the mud and rust and its all good again.
        Mine is a 2002 turbo diesel, not sure if that makes any difference?
          I used the same allen key for the filler as for the drain plug. It was pretty tight, I had to use the long end of the key, and a big shifting spanner on it.
          Mine's a 3.4L petrol.
