90 Series RV Bull Bar fit GXL?
  • 90 Series RV Bull Bar fit GXL?
    G'day
    Im wondering if a Genuine Bullbar on a 90 Series RV will fit a 90 Series GXL. Has anyone had experience in this? I have read a few past posts on this but cant find a clear answer.
    Any advice much appreciated.
    Regards
    Ben
    It should fit fine but it will look a bit odd because the flares will jut out further than the bar. I know the ARB bar from an RV will fit a GXL with the aforementioned problem. I'm not certain about the OEM toyota bar but I can't see why it won't work.
      The difference between an RV and GXL bar will only be in relation to the overall width. The gxl having the factory flares is a little wider approx 25mm either side,the RV being a little narrower due to having no flares.On my previous RV6 i had the opposite with the fitment of a TJM type 15?GXL bar that was wider but i got away with it as i fitted RV flares as well.
      So an RV bar will fit [ie bolt on] but may be a little narrower than the outer edge of the gxl flare.
        Thanks so much chaps, may you win the lotto!
