14 yr old stock coil spring, change or upgrade?
This topic is closed.
  • 14 yr old stock coil spring, change or upgrade?
    Would u think after 14 yrs the original coil springs would loose its compression rate? Coz on my long drive to Sabah,Malaysia ...when I go over a bump I can feel the rear would bottom-out I.e classist hitting feeling....n currently I'm using new stock absorbers (tokico) n 14yr old stock coil springs.... Or do I need to replace the coils with the APS springs which I mention earlier....fyi will buy steel bullbat later... I travel mostly on bitumen/tarmac
    Prado 95 3.0D Turbo Auto Series 1997, 285/70/16 Bridgestones AT 694's on 16x8 rims
    Prado91,
    You have posted this exact same question in 3 places here on PP (that I can find) and in 2 places over on www.lcool.org; - don't you think that's a bit much?? I'm sure everyone would rather see the question once, so it can be answered in once place.
    Could you please delete or edit this post:
    http://www.pradopoint.com/showthread...l=1#post350391
      Prado91,
      You can continue to use this thread for your questions relating to your coils
      http://www.pradopoint.com/showthread...S-coil-Springs
