Larger Main tank for a 97 3.4v6 ?
  • Larger Main tank for a 97 3.4v6 ?
    Hi
    there any other main tanks (from other makes models) that are larger in capcity than the standard main tank for a 97 3.4 v6 ?
    I want to increase fuel capcaity but not too keen on the plus $1000 for a pupose buit long range tank.
    thanks
    If I'm understanding your question correctly, no there isn't an OEM tank of any make or model that will bolt into a 90 series to give a larger capacity main.
    Not sure if this comes under the bracket of a "purpose built" tank which you don't want, but 4wd systems make a 155L main tank replacement.
    http://www.4wdsystems.com.au/index.php?id=25
      I'll be pulling out the log and putting in the 155 lt tank when I head to the city again. The lpg was perfect for around town but now we are living remote, capacity is now the priority
