what tyre pressures
  • what tyre pressures
    hi.
    the wifes away (only for the week) so BFG AT's have come to stay. the question is will she notice? not really!
    the REAL QUESTION is what pressures should i be running them at? the tyre fitting shop has put 34psi in them front and rear. answers for using on the road please.
    Are your tyres cold or warm?
    97 Vitara 1.6 JX Day Tripper(550klms range), 98 Prado V6 LPG GXL for Touring (1400klms range), Offroad Cub Camper for Overnight.
      Yep unladed sounds about right. Increase the rears to 38 or so if you load it up.
      Richard
      Australia (wanting to visit Scotland!)
      Richard
      2011 GXL TD Auto Prado Silver
        cold. just like everything else around here at the moment!
          The guys who fitted my Cooper ST's today suggested 38psi for the black stuff... up to 40 if needed load wise.
          Lower than 38 will give a more comfortable ride but will be noisier on the road they said.
          Cheers, Leon
          Optix Photographix
            I have a sticker on driverīs side B-pillar, it says 2.0 bar front/2.0 bar rear if 265/70R16 tires. Means about 29 psi.
            [size=1]
            2007 FJ Cruiser 6M/T[/size]
              I got my prado a few weeks ago and the previous owners had 40 in them. Is this ok for the road? Should i let a little bit out.Dueler a/ts 265/75 16
                i dont have a 90 series but ive talked to a few people and they reckon that you need to run around 38 psi to get decent tyre wear, i have 694s on my 120 and i run around 38 psi on the black, ive got ironman heavy spring kit in as well and it doesnt ride overly hard, just a bit firmer than standard
                  Here is much info about tyre pressures too: http://www.lcool.org/technical/90_serie ... tyres.html
                  [size=1]
                    Should be fine.....check the tyres maximum pressures though incase your getting close to it.
                    When I have to do extended freeway trips with my BFG MT's I stick 50psi in all 4 (Maximum rating is 65psi). Doing this helps the fuel economy too. It does make the ride a little stiffer, but thats not an issue on the freeways. There has been no uneven wear either.
                    Richard
                    Richard
