wheels nut torque figure
  • wheels nut torque figure
    to what figure should i tighten the wheel nuts on my 95 with alloy wheels?
    thanks
    i know this might be a very late reply, but i work at Toyota in Perth, and we torque all the wheels to 110nm
      Yeah only 7 years after the question was asked
        Make sure you use Newton Meters and not Foot Pounds on your torque wrench.
          Nothing like a quick response. 85 ft/lb seems to be close. Used this for the last 35 years. Never had a wheel stud fail or nut come loose.
          Rusty
            I agree - 100ft/lbs is VERY tight and just about gave me a hernia getting off again!
            Micheal.
              As an aside, the wheelnuts on my GTS are torqued to 190Nm (140ftlb). I usually have the appropriate tools at home but a few weeks ago a mate in the US asked for a closeup shot of the front brakes. I thought hmmm time to see if the supplied jack and wheel spanner are ok to use on the side of the road. My attempt at removing the first wheelnut resulted in the pressed metal wheel spanner looking more like a pretzel than a tool. So it went to land fill and I put my breaker bar and impact socket in the boot. Crazy torque but that is the factory requirement.
                We do ten stud truck rimes up to 450ft/lbs, how would the hernia go with that
                  Pretty sure you're not using the prado wheelbrace though!
                  I've also have a 'professional' mob overtighten and shear a couple of studs too - I wouldnt put more than 100ft/lbs on the prado studs...
                  Micheal.
                    My 95 series handbook states wheel nut torgue is 113 NM. Haynes manual states 112 NM
                      Always did mine at 110nm for years & years. I’m an advocate in most circumstances of torquing things up a little less than the recommended Toyota spec. I hate it when I get new tyres fitted or a wheel alignment done, then when back at home I’m correcting the way over torqued wheels nuts. What brought this about is many years previously with a previous car, a mechanic snapped a wheel stud during a service. When I came in pick the car up I was going to be charged for the replacement stud. I stuck to my guns and kept saying it was fine before bringing the car in. They ended up waiving the charge. Every single mechanic or tyre shop since have done the wheel nuts up too tight, some way too tight.
