Im new to this forum but work a 1997 90 series swb 3.0L damn hard as a beekeeper pulling up to 3tonne on a large triple axle trailer over very punishing bush tracks.
As far as overheating goes I've had some experience.
The NZ models have an air-con condenser in front of the radiator which prevents a front view of the actual radiator.
I ended up with the space between this condenser and the radiator becoming packed with grass seed.
In my case it was an easy fix for a ultra hard working truck, get rid of the air con condenser and replace the radiator, NZ$250.
This may not suit the Australian driving environment but in my view if the condenser is obstructing the radiator or as in my case is causing an obstruction to occur then you need to do something.
