90 series cruise control problems
  • 90 series cruise control problems
    Hi My name is David and am located in Adelaide
    I have a 2001 Prado RV, Diesel, 5 speed manual.
    Great car had the usual problems, new head, etc
    After reading this forum and others I decided to fit the factory cruise control
    Bought clock spring, CC stalk and clutch switch, all fitted OK
    BUT when switched on all i get is the flashing CC light on the dash
    I have checked all the tail lights, disconnected the trailer wiring from the loom.
    Any ideas what i have missed?
    regards
    David
    Hop on the Mighty 90's Facebook page. Recently someone posted about this, had great success.
    Have you wired in the safety switches for brake and clutch?
      Hi Thanks for the tip
      Yes I have fitted the clutch switch and found and connected the existing wiring loom, as far as the brake safetey switches go, no i believe they are already there.
        Hi Carco
        Thanks, I have tried to join "mighty 90's" on FB but am still waiting to be accepted ( it has been 5 Days)
        You don't happen to remember what they said on the post?
          For some reason this site won't do PM's (where I could send you the bloke's name)
          See if it works backwards, send me a PM so I can reply.
            Hi Carco
            Thanks for your help, i finally got onto the website today, and it now works
            here is a list of what need to be done
            My car is 2000 RV diesel manual 5 speed
            1) Get CC stalk, and fit to steering wheel
            2) Get clock spring and steering wheel rear plastic moulding to suit ( these are to suit each type of clocks spring, My car did not have Airbag)
            3) Change Brake switch from Brown top ( 2 Terminal) to Blue top ( 4 Terminal), wiring loom clip has 4 terminals already
            4) Install Clutch switch ( remove Bolt and replace with switch) adjust height with locknut
            5) Find wiring loom/ plug that is taped to existing loom high high up on firewall and connect to Clutch switch
            That It
            Happy motoring
              Hi Carco
              That It
              Happy motoring
                Sorry forgot to add
                All the parts were sourced fro ebay of the local wreckers except for the clutch switch, Toyota did not have stock, 6 weeks delivery and $40.00 approx
                So i bought from Rockauto in the USA, Just pick a toyota model close to the year, approx cost $25.00 including freight, delivered 1 week
                  Well done. I'd heard almost everything was already in place with the diesels.
                  I'd love to test drive a manual diesel on cruise.
                  Mines auto and it kicks back instead of lugging. I have to watch the boost and when she gets up over 10psi I know she's about to drop a cog so I take over and back off accordingly.
                  In my opinion the cruise was designed for their more powerful cars, Lexus V8, 2JZtt etc and it puts the boot in pretty hard to maintain road speed.
                  Poor old KZ can't keep up.
