Steering extension
  • Steering extension
    Hey guys and gals, just about to lift the body by 2" (50mm) and having trouble getting hold of an extension for the steering rack. Any one know where you can get them?
    '98 RV6 3.4l, HEMA Navigator, Icom ic400Pro, Safari Snorkel, Cooper STT's 235/85/16, 2" Body Lift, 2" Coil Strut Spacers, 12000lb Winch, JVC DVD Head Unit with Reverse Camera that washes itself, PradoPoint Stickers x 2, Roolite 180's, 1000w inverter, Uniden AX44 AM Cb (Better range in bush), Bell & Carroll Air Compressor, and more to come....
    Re: Steering extension
    I bought it from here: http://www.4crawler.com/4x4/ForSale/Bod ... gExtension
    [size=1]
    2007 FJ Cruiser 6M/T[/size]
      I made what kzj90 pictured, using a section of nylon rod. You just have to drill a 4 holes through it in line with the bolts and stud thingys. Oh yeah, you need longer bolts.
        Thanks guys. I had Cheezy racing make up an extension to the bar that goes through the firewall. DONT TAKE IT OUT! Should have gone with kzj90's suggestion! There is a plastic disc in between the uni just inside the firewall. Dont let that fall out! A mate and I took 3 hours to figure how it went back together!
