I have a problem. When I look through the front lights in can see that the lens are dirty. When the lights are on you can see that the light in some parts is more dark. So I wonder if this problem can be solved by cleaning the lens. Do you have any experience? Thanks.
How to clean the lens
Re: How to clean the lens
What is your location?Originally posted by slo_cruiserI have a problem.[B][SIZE=4]ntp
As per the rules for this forum, please add them to your profile so we all know where you are from. I am sure someone will have an answer for you.Originally posted by slo_cruiserSlovenia - Europe
Welcome to PPoint. 8)[B][SIZE=4]ntp
Cleaning
I actually pulled my lights write out from the vehicle. Took the bulbs out, filled up with water and some washing up detergent got a rag down in there then used a plastic spatula to push the rag around then rinsed out stuck out in sun to dry then reinstalled. Just dont play with the adjustments so when you pull out and put back in again they will be alighned correctly. SteveFace lift 150 Prado V6 auto. No mods yet
