First of all would like to say a big hello to everyone on the forums. I recently purchased a 1997 GXL and this is my first post.
When I purchased the vehicle the air conditioning was not working. The clutch on the compressor was not engaging when I switched it on and I suspected there was no gas in the system.
I recently then took it up to an air con servicer and attempted to get it re-gassed. We worked out pretty quickly it had a cracked pipe from rubbing on the chassis as the plastic support bracket had broken.
This is no big deal the pipe is cheap and I can easily replace it myself.
My question is, I am assuming the clutch on the compressor is not engaging because it has a pressure switch and knows there is no gas in the system and therefore will not engage. Would this assumption be correct?
I am hoping once I replace the pipe I can get the system pressurised and the compressor clutch will then engage when i switch the aircon on and everything will be fine. I just couldn't find the pressure switch anywhere and was worried there might be a problem with the compressor? I can also turn the the compressor pump manually and it seams to be fine and not seized or anything.
Thanks a lot for your help, it's really appreciated!
Matt
Matt
