Fog Lights Question
  • Fog Lights Question
    Hi,
    When I bought my 90 VX Grande, it had an TJM bar fitted in place of the standard front bar. I have seen plenty of 90's around with factory plastic bars and they have what look like fog-lights. I have checked under the front of mine and there are definately some connectors that have been disconnected. My question is, what activates the fog-lights from within the cab? I can find no additional switch. This makes me think they are just lights that come on with the low-beams. Can some one enlighten me on this illuminating subject :?
    David
    2013 FJ Cruiser
    265/75r17 Cooper ST Maxx, Rear locker/A-Trac/Crawl
    Losi Comp Crawler for the really rough stuff
    Re: Fog Lights Question
    I have a 2000 VX Grande and the fog light switch is on the right hand indicator lever.
    Hope this helps.
    Wayne
    2000 VX Grande 3.4L , Bonnet/Light protectors , Toyota tow bar & bullbar,Hayman Reece brake controller, GME 3220 UHF, TJM Compressor,Nane 7200 spotties, Safari Snorkel, TJM XGS Gold suspension, Magellan Crossover, Cheap GPS with Ozi Explorer and Pradopoint sticker
      Hmm, I don't have that. I guess mine didn't come with fog lights after all.
      I wonder what the connectors are for then. Will have to check wiring diagram.
      cheers
      David
      2013 FJ Cruiser
        They are for the fog lights. All the harnesses are the same...you would have to change the staulk out to make them work from the picture shown above. Do a search and you will find some more information on this. I think it is in the 120 section
        Manata 3" Exhaust, Blisten shocks, King Springs 50 mm lift, Poly Air Bags, Roof Rack, Iron Man Bull Bar, HID 50W LightForce XGT spotties, Daul Batteries, GME TX3440 & AE4705 ant, Upgraded window washer, Bonnet Scoop, Tunit chip, bonnet protector, headlight protector, Cooper STT's, ScangaugeII, Dash Mat, Endless Air, Stebel Nautilus, Diff Breathers, Water Sedimentor. ([b]Camprite TL8s [/b] Arrived ALIVE~!)
