Driversc seat sagging
  • Driversc seat sagging
    My drivers seat is starting to sag at the back of the seat squab (notthing to to with the big driver , Any weay wuill need replacing soonish, wondering if the seats out of the 120 are intercghangeable or i am looking at a aftermarket one.
    Any feedback will be appreciated
    Regards
    Gerry
    Re: Driversc seat sagging
    gphcald,
    My 90 has done the same thing with the drivers seat... Previous owner was a bigger lad so i will blame him...
    There is a metal bar in the lower part of the back rest and it digs right into my tailbone - awesome when your bouncin through the bush!
    I was thinking of taking the seat out and off to a local trim shop and getting it re-foamed to repair it and also add a bit more support (lumber, side). I have had this done to some of my other cars before and usually get out of it for a couple hundred bucks.
    Might be an avenue you can explore.
    Chris.
    [COLOR=blue]Current rig - 150 GXL D4D Auto TJM bullbar. Airtec Snorkel. ARB Underbonnet Comp.
      About six months ago I picked up a drivers seat for mine (exact same trim/colour) in virtually new condition for $120. My original was well and truly worn out on the base and the side support.
      By far easiest/cheapest option IMO, well worth a few phone calls to some local wreckers.
        Has anyone fitted aftermarket seats to the 90 Series
        cheers
        Rob
        Rob
        Silver 2010 Prado 150 TD Manual, BFG AT 256/65's, ARB Deluxe bar, Tradesman Roof Rack, Warn XP9500 winch.
          cheers
          Rob
          I had a Stratos seat fitted by Opposite Lock almost immediately after I purchased the Prado. With the factory seat I could not even drive 80km before my back was killing me. Fitting the Stratos required a special frame as the attachments to the floor are different.
          I can drive for 2 hours no problem with the Stratos seat.
          Other brands would be similar I presume.
          ray
          2001 TD Auto
            Excellent response Ray, are the Stratos comparable to say Recaro etc ?
            Rob
