Re: 2001 3 LT TD towing power
Hi Steve, WOW thats some crack in the dump pipe thanks for the info you have saved me some dollars i will look into replacing the muffler with something more free flowing as the exhaust system is still the OEM from new, lift on the suspension is approx 755mm & 785mm i have lovel springs all round and i replaced the shocks last year with toyota genuine as they were dirt cheap so far with the off road that i do their ok within their limitation actually their not to bad. On the subject of the viscous coupling i went back to toyota & also called customer care guess what (no care) no warranty because did all the work myself no way to prove that the brand new coupling was at fault, i agree with the Turbo fitter once you overheat them its all over thats one reason i fitted the Engine Watchdog its got an inbuilt alarm which i have set at 90deg c, highest its ever got is 85deg thats camper trailer in tow wife & Daughter & roof rack fully laden Two engel fridges in the back of the car going up some pretty big hills.
