Dead Seatbelt
  • Dead Seatbelt
    Another problem I have recently is that my drivers side seatbelt has locked up and is probably US. I thought I could take it apart and fix the jammed part but then read the sticker on the side that said it contains an explosive device and do not tamper. So on ring Toyota they quoted me $510 for a new seat belt (YIKES). So, can the be reconditioned or is there a cheaper alternative on the market I don't know about??? Are they hard to remove and maybe replace with a secondhand unit from the wreckers?
    Thx Mark
    Re: Dead Seatbelt
    Is it not retracting at all?
    Mines is slow to retract & the last foot or so won't go in by itself....I had heard previously of something you can put on the belt to lubricate the mechanism, but it was a long time ago & well before I had my Prado.
    It will be interesting if anyone has a solution to this.
    Richard
    2011 GXL TD Auto Prado Silver
      Re: Dead Seatbelt
      I'm pretty sure wreckers are not allowed to sell used seat belt components.
        Re: Dead Seatbelt
        The spring inside gets tired. I pulled mine apart and wound it up tighter. Cleaned the belt with soapy water. The belt gets dirt and grime on it and won't slide through the pivot properly.
        It was pretty fiddly dismantling it. But hey I was quoted more than 510 dollars for a new one. So thats why i fixed it myself.
          Re: Dead Seatbelt
          Some Prado's will have pretensioners as part of their safety package. These are explosive so I wouldn't advise dismantling one of those...
          You may have pretentioners even if you don't have airbags too......
          Richard
            Re: Dead Seatbelt
            Another area of my work makes the aftermarket seatbelts for Klippan. Give them a go.
            I work in the crash test centre so don't have anything to do with them. I walk through the factory to buy my lunch and they seem nice people 8)
            http://www.klippan.com.au/wps/wcm/co...me/Klippan_SA/
            Cheers - Phil Taylor
            Prado KZJ120 2006 GX 3.0ltr Manual TJM T13 Bar, Airtec Snorkel, Sand/snow mats, cargo barrier, Cruise, Budget Campertrailer, 8x17" steelies w/ 265/70/R17 Mickey Thompson ATZ 4 ribs, Binatone GPS, Other Stuff...
              Sometimes the seatbelts get dirt, oil and other things on the actual belt. these things make the belt stiff/hard and less flexible. As a result, the standard spring isn't enough to make it retract all the way. The solution is to soak the seatbelt in fabric softener and give it a good clean. When it is softer (and has dried), the seatbelt will often retract properly.
              HeathAU
              [B]Perth, Western Australia[/B]
              [COLOR="darkslategray"]2003 GXL Prado, 3L Turbo Diesel (120 series). Toyota Bullbar, Safari Snorkel, Sidesteps, Hella Spotties, UHF. 5spd Manual, elec tow pack[/COLOR]
                The plastic spool that the webbing winds onto frequently splits after 10-15 years which jams the works up nicely.
                Belts are an unserviceable item.
                Stupid trying to lube etc as you won't know if you really fixed it or not until you fly through the windscreen.
                I've bought replacements from wreckers, just inspect them very carefully first. Mine was from a jap import and the Oz replacement was some $600 so mint condition item from the wrecker at $60 was a good deal and acceptable risk.
                Malcom
                Prado 95 TX turbo diesel
                LC100 GXL turbo diesel
                  Had to replace the drivers side for roadworthy when I sold mine.
                  Rang wreckers EVERYWHERE in Vic and some big ones interstate, the only ones we found were also buggered.
                  In the end had to order one - could only get them from Toyota Japan, over $500 and a 6 week wait.
                  Went down the road of trying to find aftermarket replacements (available if you DON'T have airbags) and reconditioning to no avail - pretty hard to find someone to do this stuff because of all the regulations involved
