After stripping the interior out to do a major clean I came across two unused connectors at the base of the radio brackets near the front of the centre console. Can anyone shed some light on what these do? (GXL manual KZJ95 2000 model). Thanks.
Help identifying electrical connectors
I am looking at the FSM wiring diagrams.
Second photo I suspect is the socket for the auto-antenna relay.
First photo is a mystery as the manual shows no connector coming down that side of the centre. Can you give me the number of terminals, wiring colours and traces on all of them?
cheers
SteveLast edited by t303; 21-04-2018, 04:41 PM.
Thanks for that. The antenna still works for what that’s worth. The 3 pin plug is a shielded cable with black, white and red wires in pins 1,2 and 3 respectively. The other is a 21 pin housing (20 small and 1 large) of which only 11 of the small pins are populated. There’s a largish earth(w/b) and another heavy wire (yellow/black) plus a few more as pictured.
Edit: best guess on the larger plug is second row climate controls in the centre console ?2 Photos
Yep, rear console control box shows as 20pin with W-B in it for heater, dunno what Y-B is for.Originally posted by KaiZenJ95 View PostThanks for that. The antenna still works for what that’s worth. The 3 pin plug is a shielded cable with black, white and red wires in pins 1,2 and 3 respectively. The other is a 21 pin housing (20 small and 1 large) of which only 11 of the small pins are populated. There’s a largish earth(w/b) and another heavy wire (yellow/black) plus a few more as pictured.
Went through all the wiring looking for (I assume it is) a 3pin Denso type connector (same as the turbo pressure sensor connector) and drew a blank....
Perhaps if you buzz it out and it has earth/ACC/IGN wiring it was fitted after for a UHF or something?
Without looking at my Prado I would think the 3 pin might be for the Second gear start & (Auto) O/D switches as from memory they are located on the drivers side of the console.
I note you have a manual so they would not be used.'18 VX, Billies with Dobinson springs, Summit bar with Narva Enhanced Optics to help my old eyes
