Hi there.
the a/c has stopped working
Light comes on when i press the button but appears nothing starts under the hood.
there are a few tiny bubbles when engine is at 1500rpms as per Toyota workshop manual. So possibly a regas is in order.
trying to check the magnetic clutch relay but cant seem to locate in the fuse box. According to the workshop manual its located in a seperate box to the main heater relay (this tested ok).
im a newb at this so no doubt its right under my nose. Its supposedly marked MG CLT but i cant see it . So if anyone knows where it is i wld be most grateful or any suggestions as to what else i can check.
The drive belts all look to be running smooth.
many thanks
kat
many thanks
kat
