Sub tank issue
  • Sub tank issue
    Hi guys,
    i have a issue i want to share and hopefully someone with knowledge and experience can shed some light. On my 95 series prado turbo diesel, once i switch over to sub tank for fuel supply, the green light comes on.. however it doesn't deliver any fuel from the sub. It keeps drawing out from main tank. Can someone tell me what i should be checking please. I really appreciate it.
    I'd check the electrical diagram and check the changeover solenoid is getting power and if it is it might be that. PM if you want a copy of the diagrams.
    If the solenoid isn't getting power then it might be a switch or wiring issue.
      Thanks mate, ill get that checked.
      appreciate the quick response.
        If you’ve been off-roading recently a stick on the track could’ve lifted & damaged a wire for it. I damaged mine that way once many yrs ago but the stick broke the actual solenoid & the fuel leaked out. After the mechanic replaced the solenoid & told me my car was ready to be collected, and I drove it home, fuel began transferring automatically from one tank to another rapidly and would fill it within 10 mins, then the car would go to snuff out as it ran out of fuel. I’d have to switch tanks before this happened. The mechanic took 3 attempts of replacing the solenoid over the course of nearly a week before it worked properly because they kept ordering a Landcruiser solenoid & not a Prado one due to both sharing the same part number or something even though they functioned differently to one another.
