I've search the forum but haven't found anything similar.
90 Series with Factory Cruise control. VJZ95 (Petrol) GXL Snowy.
Cruise control functions properly, turns on, sets, increase speed, decrease speed, disconnect, reconnect all work as normal.
but, if you tap the brake pedal to disconnect, it will disconnect and immediately reconnect (accelerating back to speed).
If you hold the brake pedal, it disconnects and goes into an error mode (cruise control light on dash flashes slowly) and can not be reconnected until turning CC off and on again and resetting.
Any ideas how to work through the issue?
