courtisy light
  • courtisy light
    Hope thats how you spell it, Hi All,
    anyone know how to access the interior light swich above the windscreen ? I'm not sure if it is a globe as both the buttons for the lights dont work, which might mean its a fuse but everything else is O.K. is it independant {the fuse} ? if not how do you get into the casing, looked in the manual but doesn't even mention it,
    thanks in advance,
    Atheism is a non-prophet organization.
    I had to replace one of the bulbs not long after I bought my vehicle. I ended up asking a similar question on another forum. Here is the answer I got, it worked for me.
    Just get your fingers between the map light assembly and the hood lining and pull it straight down. It's clipped in with pretty strong spring clips, so
    it may hurt a bit
      if the centre roof one works then i'd assume it's bulbs up the front, if it's out too then perhaps one of the fuses that under the driver side kick panel could be blown...
        interior light
        Hi Rainman , thanks for the info mate , unfortunately I still cant get the bugar off and too scared to put more pressure on it, feels like its gonna break, should I persevere ?
        regards,
          lights
          Hi Mcbain, found that O.K. but still no mention of a fuse for interior lights, would you know where the fuse is for that ?
          thanks ,
            after i replied i realised you had a 90 series..... in the 120 series, there's a fuse box on the right of the steering wheel, about where your knee or calf would be.
            in there from memory there's a 10amp fuse with "dome" on it...
            but on the 90 series it could be anywhere, but if there's two fuse areas then normally this one's on the inside...
              fuse
              Thanks mate at least I know what fuse to look for the only one I could see that mighta been was one marked ST ?
              regards,
                Awwww crap... my Gregory's manual is in the car... just put it there today. I'll have a look tomorrow and see what I can find.
                Cheers, Leon
                Optix Photographix
                  I noticed that my central dome light is VERY weak, where can I find a stronger bulb? Is there a part number out there?
