Snorkel Time
Re: Snorkel Time
Don't think there is really that much difference between snorkels. Just comes down to availability, price and personal preference on looks. I fitted my Safari Snorkel myself and have since put it through a few water holes and the heavy recent rains ... does what it's meant to do![b]2000 Prado RV6[/b] ~ TJM Type 15 Steel Bullbar ~ Uniden 400SX-RM & GME4702 Ant ~ Front Tow/Recovery Hooks ~ ARB Recovery Kit ~ ARB CKMP12 Air Compressor ~ DIY Rear Door Trim & Table ~ Extended Diff Breathers ~ Safari Snorkel ~ Wireless Reverse Camera ~ Iron Ox Full Length Roof Rack ~ Looong Wish List ...
Re: Snorkel Time
Hi, When you install your snorkle or have someone install it for you make sure you make checking the joins a regular practice. It takes a bit of work but I had to remove the plastic guard liner the other day only to find the snorkle joints had become loose and were sucking in air. On one of my joints there was only a piece of foam rubber and it wasn't even in the joint where it was suppost to be. Just on the outside of the joint.
If some one installs it for you make sure your watching them as they do it.
If I had hit that water hole I would probably still be there as a pot hole filler.
Re: Snorkel Time
Originally posted by passin'throughHi, When you install your snorkle or have someone install it for you make sure you make checking the joins a regular practice. It takes a bit of work but I had to remove the plastic guard liner the other day only to find the snorkle joints had become loose and were sucking in air. On one of my joints there was only a piece of foam rubber and it wasn't even in the joint where it was suppost to be. Just on the outside of the joint.
If I had hit that water hole I would probably still be there as a pot hole filler.97 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
Re: Snorkel Time
Im waiting for Razorback to get these in to stock & will get one.
http://www.razorback4x4.com.au/index.ph ... &Itemid=53
Regards, JayMake it idiot proof and someone will make a better idiot.
2001 KZJ95R Grande. Dump Pipe, 3inch Exhaust, K&N Filter, Uniden UHF,
265/75 Cooper ATR's... I Love it!!!!
Re: Snorkel Time
Has anyone checked the connection between the MAF and airbox?
Noticed mine was able to be wobbled around a little bit the other day, haven't had a chance to see if it actually sucks in air through the join.<Rob> '12 Prado GX - https://www.pradopoint.com.au/forum/general/my-rig-build-up/32702-i-m-back-with-a-2012-150-gx-toorak-tractor
