Home made winch cradle
good on you for having a go McClint but i see 1 major problem with the cradle, if you have a look at any winchbar, arb, tjm, ironman or even a std toyota bar with a winch cradle they are mounted so that the winch is pulling back into the cradle or bar, they are only using the mounting bolts to hold it onto the bar, they way you have your winch mounted is that the 4 m12 bolts are taking all the weight of the car, my opinion is this could be very dangerous if the bolts were to fail and the winch came flying out of the cradle. here is a photo of an arb bar i have in the shed, see the 4 mounting holes for the winch to be mounted so it pulls back onto the bar, and doesnt rely on the bolts to take 100% of the load
i can also show you a photo of how it it mounted to a std 120 soverign bar with a winch cradle if required, im not having a dig at your work just pointing out something that i beleive could be a bit dangerous, if the pooh hit the fan cheers samohad an 03 gx 120 with some gear now got a 2013 bt 50 GT auto some ARB gear.
From my experience in breaking things in mines, in farm paddocks and up the side of a hill I probably shouldn't have tried to drive up..
Yeah Samo, I think you are on the money.[CENTER][B][U]Matt
[/CENTER]
[SIZE=2]
[/SIZE][CENTER][SIZE=2]
[/SIZE][/CENTER]
