My hidden winch setup
  • My hidden winch setup
    Installing a winch has been on my mind for a long time, but when I came across this 80series Aisin 1000 take out, I was adamant to install it.
    I must say that the task was not as easy as I thought it would be.
    1st, off went the bumper
    & other items to bare the frame and all
    dry stool fix to see & measure things
    I had anticipated that the base plate of the winch will bolt right on, but i was wrong as there are no frame horns on the 90 and its frame seems to be broader than the 80's
    [COLOR="#0000CD"]TLC 90 SWB 1KZ-TE
    50mm OEM Lift
    A work in progress & my daily driver[/COLOR]
    More of it
    finally some shape taking place
    painted up
    and just yesterday - winch up- DRY
    I reckon its not going to be THAT hidden after all
    50mm OEM Lift
      Now I need to work on the electricals & hook it up ......... that way i'll know if it even works or not
      Then the bumper needs to be put back on. Either i'll cut the original one or fabricate side pieces merged into the front plate of the winch.
      Don't know if I should cut the original one up.
      50mm OEM Lift
        Looks the goods mate,
        I had one of those winches on my 80s, couldn't stop it.
        PINKO
        Prado 150 D4D, Bilsteins, OME Coils, Air Bags, TJM Bulbar, Avenger 9.5 winch, Lightforce HGT's, Kaymar rear bar, Sidewinder Dual Battery Kit, Drifta Draws, Window Tint, Transmission Cooler, Scanguage, Caterpillar Water Separator.
