rear bar
    Sorry
    I looked at the large writing at the top not the small.
    And it is a picture of a 120 at the very top of the page not a 90 :lol:
    Craig
    03 GXL TD, factory bull bar,cooper ST's, dual batteries, IPF 900 HID spot lights, kingsprings, koni shocks, DP chip,hilux wiper jet upgrade,ATS bash plate, Snorkel, front recovery hooks, custom 3"dump pipe, 3" exhaust, ARB Compressor, ARB rear locker
      Originally posted by zookcubr
      At times they should just call this 120s pradpoint, most forget us 90s drivers.
      you said it,
      but it does give ideas for anyone to do similar,
      whether it be for a 90/120 or any type of vehicle
      [url=http://www.fuelly.com/driver/damonat/prado][img]http://www.fuelly.com/smallsig-metric/50578.png[/img][/url]
        Got a price today from All Terrain 4x4 in Vic. $2800 supplied and $2965 sent to Alice Springs.
        97 Vitara 1.6 JX Day Tripper(550klms range), 98 Prado V6 LPG GXL for Touring (1400klms range), Offroad Cub Camper for Overnight.
          I think it might be time to sell the Vitara and buy one, once I start catching the bus to work that is.
            wonder if it could be modified to suit a bodylift? would look awesome colour coded & I like the highlift jacking points.
            2000 Toyota Prado GXL- Gone, but not forgotten...
            '92 Landcruiser HDJ80 4"lift 33's
            '91 Surf LN130 coil sas, 4.8s, 35s
            '12 Jayco Eagle Outback
              Heres there contact details if you need them jkas24- http://www.allterrain4x4.com.au/compone ... Itemid,85/
                it's good to see someone fitting LED lighting to a rear bar.
                it looks good
                  Seems there doing a run of these soon and will be avaliable in the next 3 weeks if interested. Otherwise the wait is 8-9 weeks. There finnished in powder coated satin black and avaliable free of charge ATM with LED tail lights upgrade (vauled at $200). Still finding out the weight of the carrier and fitting cost. The towbar is not affected in any way even when inverted, as we have a Nathan hitch (simular to tregg) attached to our offroad Cub Kamperoo.
                    Found out the weight is 55kgs and they charge $200 to install.
                      They also make them for 120s-
                      http://www.allterrain4x4.com.au/compone ... Itemid,54/
                        Some other designs ive found overseas.
                          is priced one from the same crowd.... thats why i decided to have a go at it my self... plus i didnt like the look of the back of them....
                          as for mine.. its has been put on the back burner for the minute as i have been busy with work etc but i am hoping to get back into it in the next week or two...
                          75 Series Cruiser No More
                          Replaced with a G6E Turbo
                          95 Series Prado [url]http://www.pradopoint.com/showthread.php?19936-Beast2h-s-Prado[/url]
                          • #28
                            Re: rear bar
                            Ive started my rear bar with twin tyre carrier. Ive decided to do a simular design as allterrains in Geelong. I started with rear section from Metaland 75mm x 125mm for $70. Some scrap 5mm thick flat bar for the brackets, ive added a angled section to take some of the flex out. Added 50mm x 75mm sections either end for a Hilift jacking points. Sheet metal covers the area where the flairing was. Cut the location of the axel stubs ($20 ea from super shit auto) and welded them into place. I covered the area with some 3mm thick flat bar to protect the LED tail light I bought at Don Kyatts $153 ea. Ive tracked down my over centre spring lock downs at Ovesco in Newcastle NSW and had 2 sent to me for $54 including postage. Got my hands on some 252 Sikaflex to cover all the holes etc ($21 ea). Next step is the arms, im going to add some locking pins to keep them open ($7 ea) from Alice bolt supplies. This will be the tricky bit, working out if im going to be able to miss the rear door handle. I hope to have this project finnished before Christmas, but will see.
                            .com/a
                            • #29
                              Re: rear bar
                              Ive started my rear bar with twin tyre carrier. Ive decided to do a simular design as allterrains in Geelong... I hope to have this project finnished before Christmas, but will see.
                              Make sure you take some pics along the way so that we can all see your handy work! 8)
                              [B][SIZE=4]ntp
                              • #30
                                Re: rear bar
                                Pics added NTPRYCE, I hear your heading down our way thru Fergs. When ya coming? Might have to take you on one of our runs. Ok the bars not painted or sealed yet, still some welding and grinding to do yet but not too much to finnish this part of the project.
