Hi All,
Last weekend I fitted a reversing camera to my 90 Series Prado and I thought I would share some images.
I got the screen and camera from Jaycar the screen was $100 and the camera was $150
I chose this screen because it has no on\off button the the screen comes on when power is applied to it, also it folds down when you want it to be hidden.
The camera and screen are both hard wired to the back on the cig lighter and then to a switch on the console. So if the switch is on then they both turn on with the accessories power, off is always off.
The spare wheel can still be taken off without having to remove the camera. Also the spare wheel lock will prevent the camera from being stolen.
I did have to put some spacers (washers) on before I put the wheel back on to allow for the wires to fit behind the wheel.
I didnt have to drill and holes to fit the camera, just used the existing holes.
Here you can see the difference between the rear vision mirror and the camera.
I could'nt fit any more cables through the existing condute
