Originally posted by glen_ep
View Post
My 90 series OME 882 / 892 lift installation
Originally posted by williade View PostMore weight in the front (with winch + cradle) and heavy duty springs are better able to fight the effects of the VERY stiff sway bay.
Certainly the heavy duty springs would play into that. I'd say our weights are similiar though as I have a full size steel bullbar.
Perhaps I should disconnect the sway bar and test. I just realised I only have 1" lift in the front, how sad.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Disconnected the sway bar and took it for a test drive, boy does it roll on corners!
It allowed 40mm more droop than before (860 instead of 820).
Couldn't find a spot to properly test compression.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
