standard Prado 90 shock size
  • standard Prado 90 shock size
    Is someone know what is the standard shock size on 1999 Prado 90?
    Is there any difference between the right and left (rear) - i know there is a difference in springs.
    No difference in shocks from left to right, unlike springs wher the drivers side spring is 5mm taller.
      thanks croozza.
      I from Israel and hear the driver side is the left hand side (go figure)
      yes, i know about the springs.
      i ask all those questions because i just installed King HD springs (KTRR-59HD) but the car seems to be as the same height as standard.
      the articulation i measured with the Kings are: rear-left 53mm , rear-right 55 mm.
      i would like to compare it to standard size.
