Flex your muscles...
Originally posted by TFPRDO View PostTook these when I stopped to walk Canal Creek on our recent Cape York Trip. Iron Man 75mm lift with 265x75 BF Muddies.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Originally posted by glen_ep View PostWhat's this about a 3" lift? What suspension are you running?1999 v6, 2&?" lift, BF Goodrich Mud Terrain 265x75, TJM Rear Pro-Locker, ARB Front Locker and other stuff.
If it has a buffet. Forget it!!!!!
Originally posted by TFPRDO View PostIronman 75mm with foam cell shocks in the rear.97 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
Originally posted by croozza View PostYou do realise it is not a true 3 inch lift, the CV's do not like that angle for too long, and the rear diff would be off centre too much.1999 v6, 2&?" lift, BF Goodrich Mud Terrain 265x75, TJM Rear Pro-Locker, ARB Front Locker and other stuff.
Originally posted by TFPRDO View PostYour spot on Crooza, but 75 was what was on the box and it's much easier than saying 2 and a bit.....97 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
Originally posted by croozza View Postlol. Yep, the springs are 3 inches taller than std, but they are soft, so when they are installed, it comes back to a 2 inch, and when you have a load in the back or your towing, they drop further.[B]Declan[/B]: [SIZE=1]1997 GXL 4.5 Auto 80 series on [B][COLOR="#FF0000"]LPG[/COLOR][/B], ARB bullbar, 2" OME lift, 32" MTZ, GME UHF, rear ARB locker, Kaymar spare wheel carrier[/SIZE]
Originally posted by williade View PostI love it when manufactures (and some Prado owners) make dubious claims about their lift height.
Unfortunately, most are misled by the manufacturer. But they can get away with it because the spring is that much taller, but when installed, they aren't, that is when the claim should be made, and it should be an industry standard.97 VX Grande, with front & rear air lockers, ARB Sahara winch bar with tigers 11 winch, 2" EFS lift, 265/75/16 Achilles Desert hawk XMT, and more.
Originally posted by croozza View PostUnfortunately, most are misled by the manufacturer. But they can get away with it because the spring is that much taller, but when installed, they aren't, that is when the claim should be made, and it should be an industry standard.1999 v6, 2&?" lift, BF Goodrich Mud Terrain 265x75, TJM Rear Pro-Locker, ARB Front Locker and other stuff.
Ha Ha1999 v6, 2&?" lift, BF Goodrich Mud Terrain 265x75, TJM Rear Pro-Locker, ARB Front Locker and other stuff.
lol
TFPRDO; How about you do some detailed measurements so I can add the details to the 90's suspension guide? (see the thread for formatting)glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Originally posted by TFPRDO View PostGotta love a Prado..........[B]Declan[/B]: [SIZE=1]1997 GXL 4.5 Auto 80 series on [B][COLOR="#FF0000"]LPG[/COLOR][/B], ARB bullbar, 2" OME lift, 32" MTZ, GME UHF, rear ARB locker, Kaymar spare wheel carrier[/SIZE]
Cheers1999 v6, 2&?" lift, BF Goodrich Mud Terrain 265x75, TJM Rear Pro-Locker, ARB Front Locker and other stuff.
on a forum run up the powerlines track in mundaring, 3 inch lift, 1.5 inch bodylift, removed front swaybar, 80 series rear shocks and 33s was the only one not to lift a wheel though this section, and still had a bit more flex to go :P
am yet to extend (or remove) the rear sway barLast edited by draycon; 04-01-2012, 12:09 PM.1997 3.4 V6 Rv. mods; 1 1/2 inch bodylift, 285/75/R16 cooper STTs, 16x8 sunraysia style black steel rims '0' offset, 2 inch heavy duty springs, bilstein shocks (80 series rear), GME remote mounted UHF.
