Nolathane Suspension Bushes - opinions on please
  • Nolathane Suspension Bushes - opinions on please
    Hi
    At the end of April, as part of a bigger service, I had Pedders replace every suspension bush under my 95 with the Nolothene plastic bushes'
    This weekend driving around Abercrombie Nat Park, I had one of the front sway bar bushes 'disappear' which introduced all sorts of alarming clanking noises until I found the problem.
    I'd like to hear other opinions on these bushes which I believe are meant to be the 'ducks nuts'.
    Was this just bad luck on my part?
    Pedders seem to think so as 'yours is the only of these we've seen vanish' but they are considering replacing them with a 'softer' compound.
    Whats other peoples experience with this type of bush?
    Malcom
    Prado 95 TX turbo diesel
    LC100 GXL turbo diesel
    to hard no give less wheel travel....... rubber is much better and lasts longer
      have to agree there, way too hard. Its not like its a track car Would have thought that they would steer you to the right product. But then based on my experience the bull in pedders is exactly that.
        Pedders rubbish, I just had to replace the Pedders shocks on my Triton 4WD after 18 months, under warranty, because the bottom mount bushes had disintergrated from only driving on the street.
        I would only recommend Fulcrum Super Pro Bushes for any subframe
        Auss15
