spring rates and ride height
  • spring rates and ride height
    Can anyone tell me whether spring rates have any effect on vehicle ride height?
    Bushtreka
    Prado 150D (2017) & Prado 90 V6 3.4L (1997)
    Bushtreka,
    If two sets of springs have the same free height then the spring rate will determine ride height.
    Conversely different free heights with the same spring rate will have different ride heights.
    Naturally a longer free height with a higher spring rate will have a higher ride height then a shorter/ lower rate etc.
    If you increase the spring rate and shorten your free height to try and maintain ride height with better load carrying capacity you run the risk of the springs coming loose/free at full droop, (the early Rangies had a issue with that occuring )
    Lee
      Use the spring equation:
      x=-km
      x=deflection (compression)
      k=spring rate
      m=mass
        Thanks guys that answers my question
