King Springs??
    Originally posted by wholesalesuspension View Post
    How long ago was that one Dan?, as they have been using X5K steel for a few years now which has improved quality dramatically. They also offer a lifetime warrantu against sagging.
    Regards, Jason.
    Mate off the top of my head i'd say around 2005-2006 sometime...........I purchased them from the Big Chicken shop and fitted them my self.........I put Dobinson raised 2'' shocks in and big chicken springs for a 50mm lift........In the rear.....can't remember if they were constant load or not now?......
    I fitted them at the time because I was towing a 6mtr plate boat around for work and the standard ones never cut it from the start although they did have 250k under their belt already..........My tow ball weight would not have been much more than 100kg though from memory.
    Dan
    22'' Lightbar......
      Dan
      Ahh, i think they went to X5K steel in 2009
      Regards, Jason.
        Regards, Jason.
        Do Kings make the chicken ones?
        Dan
        22'' Lightbar......
          Chicken one's?
            Chicken one's?
            Emu.......Big Chicken?..
            22'' Lightbar......
              Hahahaha Gold!!!..... They do make some for the Big Chicken mob, and i'll let you fill in the blanks with some others they supply some springs, but not all to.
              A_ _ , T _ _, E _ _, Ir _ _ _ _ _.... King's only make some for these guys, but they have all moved a lot of their purchasing offshore for the almighty dollar.
              A lot of the springs Kings make for these other companies are made to their own unique specs.
              They also make Tough Dog's coil springs for them. Mostly to their own specs.
              Regards, Jason.
              wholesalesuspension
                King Springs??
                So Jason if kings make them for the big chicken shop and it's the shops secret recipe of herbs and spices, then I'm not comparing apples with apples when comparing the 2 brands yeah? Do you know if the big chicken shop ones are this X5K steel
                Matt
                Rig build here
                  Matt
                  Personally Matt i'd be looking into Dobinson a fair bit also........I had them in my 120 with Bilsteins and they were a good match and the ride was pretty bloody good........I wish I had of kept the spring rate numbers etc to pass it on.......Our local suspension joint here in Darwin suggested the package and he I would have to say was pretty spot on.
                  Dan
                  22'' Lightbar......
                    Cheers Dan , yes I have been looking at them as mine will be coming out hopefully sooner than later. The Brissy 4x4 show snuck up on me but booked the day off Friday and am heading in talk to the blokes from dobinson to see what they recommend.
                    Matt
                    Rig build here
                      Matt
                      I believe all would be X5K steel that Kings Produce.
                      If you can get some secret ingredients out of the other guys, ie: spring rates, lengths etc, i can compare to my Kings database.
                      Regards, Jason.
                        Hey Jason I have an 08 D4D with an arb deluxe bar& dual batteries with a big chicken lift.The coils in the front are 390 high and lbf/ 590. & 103N/mm
                        The ones in the back are 390 mm high and lbf/245 & N/mm-45
                        Rig build here
                          They are a bit like a Dobinson in the front in that they run a softer spring rate and a longer coil.
                          The Front comparable King is 375mm long and 660lb rate.
                          for the Rear the comparable King is 390mm lond and 260lb rate
                          Regards, Jason.
