Am looking at getting this fitted in the next few weeks and am just after some views on which spring and shock combination would work together, would really like to hear from others that have OME suspension already.
The shocks are either comfort or firm but there are a number of spring options. The 880/890 springs should go with the comfort shocks all others with firm.
Front Spring Options:
OME880 - Up to 50kg extra
OME881 - 50-150kg extra
OME882 - Over 150kg extra
Rear Options:
OME890 - No Load
OME891 - Constant 150kg
OME892 - Constant 300kg
I have a ARB Sahara bar and under bonnet compressor - not intending to get a winch. The rear may get roller draws but also depends on if they fit with the rear A/C or not. So not heaps of weight to carry around every day, but enough over the front end now to drop it about 15mm from stock.
The current setup I am considering is OME881 and firm shocks at the front and OME890 with firm shocks at the rear. If i need to, will fit poly airs for when its loaded up to go away - which is why I prefer the firm shocks.
Any ideas or suggestions are welcome - only restraint is it must be OME, cant get any other brands
Rear Options:
OME890 - No Load
