suspension upgrade, how about the brake balance
  • suspension upgrade, how about the brake balance
    In the suspension discusion corner I see al lot of topics about the suspension upgrade, but what I don’t reed is how you did it with the brake-balance :?
    I think because you change the height of the car, you change the setting of the brake-balance (cargo adjustment) :roll:
    How did you change/adjust this? or did you not change this?
    Re: suspension upgrade, how about the brake balance
    nobody ... :cry:
      I didn't change mine, it doesn't seem to be very sensitive, I had a 2" lift in my last car, a 4Runner and the brake bias change was immediately noticeable, so I relocated the bracket, but on the Prado I felt no difference in the braking performance after a 3" lift *shrugs*
      [url=http://www.4wdmonthly.com.au/forum/showthread.php?t=29022]My Prado[/url]
        Hi BorS. The 2" lift has the affect of fooling the brake bias valve into thinking the rear of the vehicle is lifting under braking or is very lightly loaded and therefore the valve reduces braking pressure to the rear brakes to prevent locking up. The link should be lengthened until unloaded braking pressure is restored. Can check on testing station rolling brake tester. Cheers, Derb.
        2005 100 Series Landcruiser. 4.2 T/D 5 speed auto. LTD c/w AHC/Leather etc.
          Last Saturday, we changed the spring and shocks.
          I had a had look at the adjuster and did not have the idée that it matters much how high the suspension is.
          We measured the brake force ad a braking bench. Before the mod 3,5 after 3.0. On the road I did not feel anything about this chance
