Wow libraboy, 35" in simex is actually more of a 36"!! Show us a photo!
Anyone tried 35" tyres
If its purely for mud bashing, 35's would be sweet. But on rocks it could get very close the failure point of even the stronger rear axle shafts. If you have lockers, and you really should if you like rocks, then I reckon it the axle shafts are a ticking time bomb.
Having semi floating axles in the rear means you need a flat bed to get home if you snap a half shaft, unless you can repair it in the field that is
For rock crawling/steep climbs, 33's are probably the upper limit of what I would trust the 90 series drive line with.[B]Declan[/B]: [SIZE=1]1997 GXL 4.5 Auto 80 series on [B][COLOR="#FF0000"]LPG[/COLOR][/B], ARB bullbar, 2" OME lift, 32" MTZ, GME UHF, rear ARB locker, Kaymar spare wheel carrier[/SIZE]
35" tires give you a super nice ground clearance. Also with 35" will be harder to hit somewhere in the underside.
Unfortunately they are too big for our front driveline I think. The width and the weight are the most counterproductive things. They are the main causes that give problems.
I'm with williade, 255/85 ( glen_ep Prado ), 285/75 or 265/80/ ( Super Swamper Radial TSL off road only ).
CheersPrado RZJ90. OME 881 coils Nitrocharger Sport shocks front, 80 Series front coils & rear 80 series Tokico shocks rear, 255/85R16 Cooper Discoverer ST, Viper rocksliders, parking brake cable rear axle bracket, extended rear brake line, extended diff breathers, headers, engine perfomance mods, soon LR upper control arms, ARB rear locker in the future.
It really depends on what the vehicle is being used for.
I doubt Arctic trucks go through the kind of rough rocky treatment that our Aussie 4x4's do.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
hahaha that it is... silverstone version of it is much smaller. its in my build up thread that i finally updated =P http://www.pradopoint.com/showthread...ries-evolutionOriginally posted by glen_ep View PostWow libraboy, 35" in simex is actually more of a 36"!! Show us a photo!
3.0 Prado KZJ90R
King Springs and Koni Shocks 2" Lift, Simex Extreme Trekker 35/10.5 + 16"X8" Rim, Yokohama Geolander AT 315/75 + 16"X10" Rim, Piak Bullbar, Roof Rack, IPF 900XS, Hi-Lift Jack 48"
[url]http://tinyurl.com/7osm3nn[/url]
i actually dont see why you would need them, pic the right line up the track and 33s will get you up, i climbed a pretty knarling spot today with just some lift and some 33s (not even a locker :P) look for the day trips in jan thread in trip planning, some photos should be up in a few days1997 3.4 V6 Rv. mods; 1 1/2 inch bodylift, 285/75/R16 cooper STTs, 16x8 sunraysia style black steel rims '0' offset, 2 inch heavy duty springs, bilstein shocks (80 series rear), GME remote mounted UHF.
